Weber 40 DCOE 2002ti air intake
Nathan
Hello - I am looking for the short angled intake air horns that mount 40DCOE carbs to make the connection with the air box rubber boot.
This is for a ti set up with an original (4) port air box. Parallel sided air horns are available from Pierce Manifolds and I suppose could be cut and modified to match the angle of the air box.
Does anyone have experience with this? I understand Weber used to make angles air horns for 40's but has stopped.
Thanks
Nathan
Edited by Nathan
76 2002 - dual Webers/Granatrot
74 Baur - rare euro find - full restoration with ti conversion
73 2002 tii CA blue plate - full restoration
 I welded some angled old 45mm stacks on to 40mm collars, then used "ti" intake accordions. They do *not* line up as nicely as the original Solex carbs do. Also had to play with porting them, to avoid a steep "step" inside the horns. Get creative. Make what you need.
Paul Wegweiser
