5 hours ago, Mike G said:
They’re not the offset style, I thought they were meant to bring the arms back to horizontal on a lowered car but I just measured and my arms are lower at the strut than subframe.
They're designed to keep the lower arms lower at the strut and higher at the subframe- this is the whole talk about roll center stuff.
I don't know- the camber plates don't look like a lot of added negative camber, but I don't know much about IE stuff.  My car is pretty low, which just adds negative camber, let alone the GC camber plates...
Dave.
On 4/15/2019 at 8:36 AM, irdave said:
Someone correct me if I'm wrong, but unless they're offset roll center spacers, they will actually decrease negative camber, no?  The lower control arm is fixed length; it will be longest when it's horizontal; as it moves away from horizontal the X component will get shorter, no?  Which will pull the bottom of the tire in towards the center of the chassis, decreasing negative camber?
Got a picture of the strut tops / camber plates?
It depends on where the control arm position is before the spacer is added.
If it's angled up above the horizon, then adding the spacer to move them down will push the bottom of the wheel out, unless it pushes too far and starts to angle the arm down.
John Baas
1976 BMW 2002
2001 BMW M5
My Blog!
The camber plates don't add much, 5/8 degree per the website.  I thought it was more than that.
John Baas
1976 BMW 2002
2001 BMW M5
My Blog!
16 hours ago, lowniss37 said:
Found some goodies looking through some folders !
Very nice and rare: an early 1976 CA version in Schwarz with Nylon Brown interior (a.k.a, tan or beige), and sunroof with lowered front seats! A 237xxxx car probably, manufactured between September and November 1975. Original owner? I ask this because few others kept the mileage stickers...?
Below, from my original-owner 1976. Oops: can’t find a photo of my mileage sticker...?
Nice documents as well on yours. I am not the original owner and yes it is a 237 car. Everyday I am thankful that I have a E10 again. The Schwarz black makes these things very classy looking with the belt line trim and polished chip guards on the front lower quarter panel.
Randy
What?  Seriously?  Maybe it's part of their 'complete package' where that's what they want the car to have with the rest of their parts installed...
Dave.
Randy
E114.
  • Haha 1
Ray
Pfft. Bumping up a few kerbs at speed would add more.
rtheriaque wrote:
My struts were bent.
Is that no longer a thing?
:P
Ray
