Got the reply back from the BMW Historics Group about the Inka car, seems it's an early '72 car.
"The BMW 2002 US VIN 2580696 was manufactured on January 28th, 1972 and delivered on January 31st, 1972 to the BMW importer Hoffman Motors Corp. in New York City. The original colour was Inka, paint code 022."
I'll add this to the database
Ed
  • Like 3
'69 Granada... long, long ago
'71 Manila..such a great car
'67 Granada 2000CS...way cool
2 hours ago, jp5Touring said:
Button up the interior after gauges  and Nav install. Went for a 90 minute drive.
Sitting at a light trying to figure out why my turn signals won't work ??
Oh yeah it's the stalk on the right side,, been a while. ?
after driving the 02 all summer I get back in my truck and signal turns with the windshield wipers.
  • Haha 3
Replaced a cracked giubo, and in the process noticed that my transmission mount was destroyed and offset:
Shifted the trans mounting plate to align the mount during the reinstall of the giubo and mount.
1972 BMW Inka 2002Tii  ?
1974 BMW Turkis 3.0 CSi ?
1972 MBZ Weiss 280SE 4.5
2006 BMW Cobalt 530i (38,700 m original)
I would suggest upgrading to the e21 transmission mount, much bigger and less flexible.
I had it in my hand!  I bought two of them for my E9 - It looked too big for the Tii.
Well, next time I'm under the car...
Started tearing into the pedal box (more like puddle box) to replace the leaking clutch master cylinder. 175096043_2002puddlebox.thumb.jpg.0efae70739a9f88d92b4cbc263f4fc04.jpg
Should I pull the whole pedal box or leave it in place? I've got a pedal rebuild kit from blunt, but I am a little hesitant to break the seal between the box and frame (heavy coat of POR-15, with silicone in between). Afraid with my luck I will completely unthread the vacuum booster bracket bolt...
Got a new slave cylinder to put in too... Didn't realize there was such little clearance between transmission tunnel and 5 speed... I do have a little access panel cut into the tunnel which I most likely will need to use.
Getting really anxious to go for a drive now that spring weather is upon us. Really torn between just replacing the master cylinder and leaving at that, or having the peace of mind that my clutch pedal will be good for awhile.
Installed a vacuum selector switch to see the difference between ported vs. manifold vacuum to the distributor.
I have always used manifold advance. Low compression and the new gas suggest a 10-degree vac advance at idle is best.
My dizzy has about 2-degrees mechanical advance at 900rpm, so total is 15-degrees with a 3-degree static.
I'm curious to see how throttle response will be with ported vacuum (no advance at idle).
Ahhh...."Idle" minds create WOT (wide open thoughts).
245975119_ManifoldPortedSelectorSwitch.thumb.JPG.1045356447af78b400195c3ab5aa188e.JPGIMG_5125.thumb.JPG.80d4f49c5c692d83ab35ff962d3af0bb.JPG
  • Like 6
Great minds…. Doing some fine-tuning of my driveshaft alignment today.  Lowered the transmission mount by 1/8” and adjusted the tail of the gearbox slightly to the driver’s side.  Don’t dare let it sit any closer, as it’s perilously close to the tunnel.  This was as close as I could get to even-steven gaps between giubo and transmission outlet flange — a little gap, maybe 1/32”, right at the bottom.  Any opinions on whether this is close enough to button up?  I’m not sure how I could get it much more even…
Edited by 0257
Forgot video attachment
‘74 Fjord 2002tii (Zouave)
’80 Alpenweiss 528i (Evelyn)
’05 R53 Chili Red Mini S
‘56 Savage Model 99 in .250-3000
IMG_5926.MOV
Looks ok to me
On 4/18/2022 at 6:49 PM, Mike G said:
On 4/18/2022 at 6:18 PM, mccusername said:
Mmm those smell like carbon fiber flares.
there’s tape on the roof ?
The Tape is probably holding the Carbon Roof in place while the bonding cures ?
I don't take myself or opinions Seriously
My 4th 2002 and the first set of Square Tail-Lights
See the 4 versions of my 2002 project here: SoCal S2002 | Facebook
