Rear sway bar bracket
Dennosaurus
Make absolutely sure the bolts you use are not too long. If they are, they will bottom out on the rear subframe before the bracket gets fully tight, and strip the welded-on nuts of the subframe! Rear brackets are the same part number as front brackets, by the way. Hope this helps!
Paul Wegweiser
