What 5 speed transmission did I buy?
Zeephyrin
Hi,
I plan to do 5 speed conversion and the only 5 speed gearbox which the seller had I brought home. Looking at it, I am not exactly sure, what type it is and what are the gears. Can you please advise?
thank you,
Martin
Edited by Zeephyrin
Taking out the price of the item
Looks like a similar issue that someone had just recently. Bought m20 gearbox to install to m10. It doesn't fit.
I can't find the thread now. In that case you don't have to worry about gears because you're not able to install it.
You're probably located in Europe or elsewhere but in US. That makes the mistake more probable because m20 5-speeds are easier to come by than m10 ones.
6 hours ago, Simeon said:
Casting number. I think the extension section means it is definitely a 5 speed, just not for an M10
+1
I suspect that casting number is on the rear cover, which may well be shared by multiple transmissions.  But the trans is far too long for a 4-speed.
Edited by Conserv
Measure the spacing between the two top holes that correspond to the flat spot on the block that appears at 1 to 2 o'clock as viewed from the rear of the block and correspondingly the front of the transmission. The spacing for the M10 is 4.75 inches while the M20 is 5.5 inches. The transmissions are not interchangeable because the bell housing/block patterns are different.
73 2002 Tii Sold
71 2002 Ti Vintage racecar
84 BMW 325 E-Prod racecar Sold
The fact that the reverse switch is on the rear tells me it is definitely not the 245 that we know and love.  There's a thread with a post by Ace Andrew that lists the various gearboxes and I know I've seen this one on that list.  I just can't seem to find that thread (but I saw it a few days ago).
Ya know, it does resemble the close ratio 5-speed.  If it is, you just struck gold.
Although, M20 application seems like the more likely answer.
Edited by Healey3000
A lot of good info, thanks a lot.
Now I think I know what I've got: the spacing between the two top holes is 5.5", plus the position of backup switch indicates it likely is for EU version of E21 M20 car, dog leg close ratio box. Not exactly what I need, besides it might be sought after by E21 crowd. I did not pay much for it, so will need to look for the right box once more time.
Martin
X2
Close/Ratio Getrag 245/11 Transmission for the E21 323i or 320/6 (M20 6-cylinder).
If you find the front section from an M10 Getrag 245, it can be swapped on by an experienced transmission shop with the right tools.  The left-over M20-compatible front section has value for someone doing an M20'02 build.
No E21.
If E21 there should be a speedo cable junction, but there isn't:
My guess is E28 and it's definitely from an M20. Not only because of the distance of the two mentioned holes but also because of their bigger diameter.
Interesting to know about the code stamped above between these two holes. GH for example stands for E21 with M10 (not late 315), GG stands for E21 with M20.
hen
