E6 touring front vent problem
70fever
I'm restoring my 02 touring and have some problem with front vent and b pillar seals. They are in terrible condition , need to be replaced but i can't find them anywhere as they are NLA.
Does anyone know if  the saloon seals can be adapted to fit touring?  How to? or if you have any other suggestion , please recommend.
Thank you.
1 hour ago, halboyles said:
Cool. Those seals were NLA last year when I was refurbishing my Touring. Considering W & N's €49 shipping costs now, they would be cheaper to get in the US, unless you're ordering many parts.
https://www.getbmwparts.com/oem-parts/bmw-left-vent-window-gasket-h51710-51361803163
Maybe BMW will make the B-Pillar seal & chrome piece for the Touring available again (one day).
Les
'74 '02 - Jade Touring (RHD)
'76 '02 - Delk's "Da Beater"
FAQ Member #17
Thank you.
Try emailing this guy in Germany.
lapo-classics@gmx.de
I bought a couple of good (used) B-Pillar chrome pieces (NLA) from him after the body shop threw mine away.
Les
FAQ Member #17
You should be commended for your restraint...
7 hours ago, halboyles said:
Already got this parts , The one that i'm looking for is the triangle vent seal at front doors and vertical B-pillar seals.
Do you have any source?
Maybe not worth reproducing , touring not much around.. :(
Thank you , i'll try.
What about cut and glue saloon parts to fit? They seem to be a little bigger than touring , is it work?
Thank you guys.
Thank you guys.
The Touring's B-Pillar seal & the chromed piece are around 10mm longer than the saloon equivalent. So, basically, you will have a gap (top or bottom) if you use the saloon part.
The B-Pillar saloon seal is not expensive (unusual for BMW) so you could try it and see how it looks.
I'm not a fan of trying to cut and paste seals; as I mentioned earlier, the rear side window seals were NLA last year and I used saloon seals butted up to part of my old original. Looks terrible and the quality/stiffness of the OEM seal is not what they once were. I'll now replace them with "available again" Touring seals.
DSCN2792sm.JPG.0af26c03037a40a465b2fa7ecae61e19.JPGDSCN2793sm.JPG.ca442cab7932d153f9c70838cb80f6aa.JPGDSCN2975sm.JPG.9f65559610a971af7d4ee2ee22d6608c.JPG
Les
FAQ Member #17
