WTB: 320i radiator, fuel pump, pre-pump/level sender and half shafts/rear axles
Freude am Fahren
19 hours ago, Freude am Fahren said:
Since I have an early car, the manual specifies an E21 323 pre-pump/sender unit.
I probably have what you need, but if you could clarify:
What do you mean by "early car"
and
what manual are you referring to?
and
do you have the part no. referred to by E21 323 pre-pump/sender?  is the pump to be in the tank or inline?
If you investigate, the injection rail on a S14 operates at 3bar.  Early o,n 3 bar pumps were not yet developed, so they used two pumps in series to achieve 3bar pressure.
Jim,
by early car i mean a round tail light. And by manual I mean the aardvark M2 conversion manual. I’m actually looking for both pumps, the inline electric pump and in the in tank pre-pump/sender. I sadly don’t have part numbers
and
and
6 hours ago, Freude am Fahren said:
What about a 318i M42 pump? Would that generate enough mojo?
Yes.
Also since you are using Aardvark's manual, are you in need of the hose fitting 12-64-1-439-225 for the hose to the radiator that provides a vent for the head air vent?  I have one laying around
  • 2 months later...
