Help needed on dipstick tube length
Themis
Meh. Just fill it up to spec, then dip your stick till it’s at the full point. Mark it, measure it, trim it. Done :)
I finally got around to putting a pass-thru into my honking big air filter so I no longer have to remove the filter to check my oil. The dipstick is outa a modern Citroen, but I need to cut it to length, measure the oil level exactly as I mentioned above, and then create a metal clamp/stop/O-ring seal to ‘calibrate’
Before in order to fit the filter I had to cut down the metal tube and add on a flexible silicone hose and bend the dipstick at a 90 degree angle.
