WTB a set of early 1600 2-piston brake calipers
joe18d
I did an extensive search last year for these calipers and was not able to locate any.  I ended up rebuilding mine, but I went through several seals before I found the correct diameter..  If yours are rebuild-able, I'd be happy to share where I found and purchased parts.
1968 BMW 2002    2003 BMW 325Ci    2013 BMW X5
Mid 70's Alfa's used ATE 2 piston calipers.  What are the mounting ear spacing in mm on yours, been a long time since I saw a set of these and can't remember that distance?  I have set on Alfa calipers that I can measure and they are probably easy and cheap to pick up  Rotors are about the same size.  can measure those too if needed.
Thanks, Rick
