Door seals
Emyers
All, considering replacing the door seals on my 02. Not been much chatter reference the fit of the URO brand lately.  Does anyone know if the rubber formulation has ever been changed as was put forward by the
Sales rep some time back as a fix for the issues regarding fit?  The current items on the car are the original BMW seals purchased eons ago and with the exception of the trailing edge of the gasket on the window glass,
is in pretty good condition. If I could get something to replace that stretch of gasket that would work and not look untoward I would consider that route.  Just thought I would ask the group...lots of experience out there!
Thanks!
Earl
74 02Lux
15 M235i
72 Volvo 1800ES
This is usually the only section of the door gasket that goes bad--there's $$$ to be made for someone who's willing and able to reproduce this one piece.  The whole gasket is made up of several different pieces glued together--including the trailing edge window seal, so it could be supplied as a separate part...hint, hint...
Edited by mike
I had bought URO door seals several years ago ahead of my Touring refurb. I ran into the "bad fit" problems like others.
I ended up re-using my old door seals over the window and toward the front (they were in pretty good shape), and used the UROs down the B-pillar. Worked out great.
16 minutes ago, Stuart said:
Have the URO seals in our 73 and it takes a serious slam to shut the doors.  The URO seals are almost a 1/2" thicker and more firm.   Bought a set of used OE seals and will install them instead.
Same here. I started shaving them down a bit in the extra tight spaces, and am otherwise hoping they'll at least soften up over time to make closing the doors easier.
After 2-3 years with URO brand door seals mine have definitely softened, I may have also become a little numb to them but I can close my doors now with more of just a latch click as opposed to a whack window rattler!!
Sent from my SM-G950U using Tapatalk
Dave R.
1975 Inka 2002a
I know nothing about URO door deals first hand. But even OEM door seals have their....inconsistencies. My ‘76, at its recent re-paint, got a pair of OEM door seals I purchased in 1983, when I believed all new ‘02 parts would become extinct before I got around to the Big Re-Paint. The left seal operates like the ‘76’s original factory seal: beautifully. But the right seal takes a very firm hand to latch the door completely. Their installations look similar, and they were still in matched plastic bags from BMW when I pulled them from storage, but the right seal looks a tad thicker.
I think your odds of a good fit are better with OEM seals, but there are no guarantees where door seals are concerned. I put NOS Ford OEM door seals on the ‘61 F-350. Curiously, the left side works beautifully but the right side takes a very firm hand!  ?
Edited by Conserv
I appreciate all who replied to my post.  I have purchased some seals from a FAQ member that were lightly used.  I will try the full install first and if that does not work out, I will graft the good trailing edge (B Pillar) on my current seals that are serviceable minus the B pillar as suggested by 02Les.
Earl
74 02Lux
15 M235i
72 Volvo 1800ES
  • 7 months later...
3 hours ago, URO Parts Support said:
Hi Emyers, we've been redesigning these seals over the last year and should have the new version available mid-to-late 2019.  The old version works, but there was certainly room for improvement - stay tuned!
That’s great news. Can I respectfully ask that the new design If differentiated some how ( different SKU?) from the old ones just so it is clear which ones we are buying.
Thank you
Earl, Ray is good at putting on door seals, ask him for help.
Don
Don
Had cardiac bypass surgery ,triple bypass, two weeks ago and  just getting back to the computer .  Don, Ray eats too much ice cream.
74 02Lux
15 M235i
72 Volvo 1800ES
Yes, yes he does.
GET WELL!!!!!
Don
