My Baur progress - adding some details
2002FjordBaur
Adding some detailing to the car...
Home made under bonnet stickers, a repainted Baur badge and the original VIN plate back on until i can get the new one printed and stamped.
Under hood sound deadening panels - i know not strictly original spec but thought i'd try a full coverage and see if it helps with suppressing engine noise? However, not sure if i have the correct
material? I've used a 20mm closed-cell foam but it does feel very soft and easily damaged - lets see if it lasts?
And some 3D printed homemade HT lead clamps – i have some lovely blue silicone HT leads that were just looking a bit unkempt!
  • Like 7
Franc.
The car looks clean.
What material did you use for the spark plug wire holders?  I've been trying to figure out what I want to do about my wires- thank you for getting me to think about the problem this way.
Dave.
38 minutes ago, irdave said:
Franc.
Printed those clamps in ABS and a couple of adapted 'L' brackets for the metal part. Seems to be holding up okay so far, but they are close to a strong heat source so lets see how long they last? I should get a laser temp gun and see what sort of heat they're exposed to?
But i only use ABS with anything i print for the car, obviously nothing safety critical but a lot of trim, gear knob, handbrake grip, knobs and heater box supports/fins have all been printed and are performing well.
If i could find a realistic chrome spray paint, i have a couple of Baur specific bits of trim i'm hoping to print as well.
Edited by franc falco
