GENUINE *BMW FACTORY TOOL* 2002 tii KUGELFISCHER INJECTOR PU
alixta
3 hours ago, PaulTWinterton said:
I find that the pulley can be soooo tight that even a large gear puller can be maxed before the pulley pops.
Mine has been off a few times so it was realitivly uneventful
when i reinstall I always add a Liberal amount of synthetic grease to the pulley wheel
Edited by chargin
I don't take myself or opinions Seriously
My 4th 2002 and the first set of Square Tail-Lights
See the 4 versions of my 2002 project here: SoCal S2002 | Facebook
fwiw, I find that removing stuck stuff with a puller can be much more effective if you tap=Tap=TAP on the part with a small hammer,
I learnt that trick pulling flywheels off rotary engines. They have a single taper held on by a very large nut. It's more of a whack whack than a tap tap. I also learnt not to get your finger between the mallet & flywheel when doing the whacking. [emoji44]
6 hours ago, '76mintgrün'02 said:
fwiw, I find that removing stuck stuff with a puller can be much more effective if you tap=Tap=TAP on the part with a small hammer, once pressure's applied by the puller.  A punch can help place the 'shock' in towards the center, where it's needed and keep from denting things up.
I am not implying that you don't know that trick, Paul... just putting it out there for future readers.
My old buddy Willie taught me that trick.
Tom
That and careful use of heat. I carefully used a propane torch (with a fire extinguisher handy). Fuel lines already disconnected and tucked away.
Colin K.
Malaga '72 tii
13 hours ago, Conserv said:
I agree, Simeon: the “bar and the bolt” look original; the pulling hooks look a bit...sketchy... ?
So it’s original, but no longer “numbers-matching”.
I think it's certainly number's matching.  I had to actually open the bag that mine came in to photograph it (I have never used it / needed it).  The hooks on mine look just as "sketchy", or hand formed, but without the patina.
(the complete set minus the fuel pressure gauge.  They wanted $575 for the pressure gauge, and I thought better of it, being the early 90's that was a lot of money).IMG_5910.thumb.JPG.f96e79a71ad792de09c05e3ca1de90d4.JPG
The article in question
This is an example of the packaging it came in (not the package for the puller, it has marker written over the label)
Any society that would give up a little liberty to gain a little security will deserve neither and lose both.
Benjamin Franklin
73 tii (Verona, survivor, owned since '92)
66 DS21 (most technologically advanced car of the 20th Century)
17 hours ago, Simeon said:
Maybe the bolt in the middle is ‘factory’
The center bolt should have a ball bearing inserted in the end (see previous post photo).
Benjamin Franklin
I didn't know that.  It beats the generic puller with steel point.  Also, you don't have to remove the rad.
Now I want one!  Anyone able to make a bunch?
73 Inka Tii #2762958
On 10/24/2018 at 3:45 PM, chargin said:
I needed that tool last week, I had to “Restomod” one
Thanks!  I'm thinking of sending my KF Pump off for testing... I would not have known how to get that rascal off!
1972 BMW Inka 2002Tii  ?
1974 BMW Turkis 3.0 CSi ?
1972 MBZ Weiss 280SE 4.5
2006 BMW Cobalt 530i (38,700 m original)
Will this work?  It looks like the jaws will reverse.
I don't think I could make one for this price in CH.  I will risk the $24 (free shipping)
I guess pulling the radiator would be mandatory.
https://www.banggood.com/75100150mm-Two-Jaw-Arm-Bolt-Gear-Wheel-Bearing-Puller-Repair-Tool-p-1116679.html?rmmds=search&ID=49642&cur_warehouse=CN
Edited by Swiss 2002Tii
additional info
Yes, it should work as long as the feet will fit in the holes.  Be careful tp keep the puller centered.  It will tend to wander.
Yes, pulling the rad is mandatory.
Previously I used the “Free” autozone loaner and it worked without the radiator
for or me it was easier to fab my tool than take the rad and electric fan out
getting my my fan out is a PITA!CD5C25A5-5F3F-4792-9288-BA4AA659724C.thumb.jpeg.f11208cdd217ed3667d0315cea7da9bc.jpeg
