Turn Signal missing cancel tab?
Tim of Capitola
Worked to change the steering wheel to new one. So now I screwed up both turn signals, need to move the tab again.
Oh and the OMP hub adapter won't work unless I wrap the horn power wire around the shaft three times. Yeah right.
To tired and walked away for the night.  Wiring is not my forte.
  • Haha 1
13 hours ago, jp5Touring said:
I think I'm missing the slip ring on the column . I'm guessing there should be one ?
Picture of one installed anyone ?
Do you mean the contact ring for the horn?  This photo shows the column and an e21 wheel I had installed for a while, before finding a stock steering wheel.
( the pin is on the wheel in the 2002 and on the column in the e21, so it takes a little creativity to make the horn work )
the photo also shows the e21 signal tab... fwiw.
Tom
Tom, yes I think I can use the contact ring off the old wheel.  Old wheel was pretty cobble up to fit my car, but the ring is good.
I just need to mount either a factory plunger and ring and I should be good to go. Will see if new plunger hub will also work.
Just not familiar enough with what a stock correct setup would be. He had a little aluminum bracket and some other goodies in there.
The the bottom plastic tray was broken to remove that piece on the column, so will look into a used one of those also.
Will get it just should have been a simple job.   Will be much nicer in the end. Again thank you for all the help.
