I wanna E21 coolant branch
ray_
... but, but, but don't you need the coolant nipple to heat the intake manifold?
the e21 dividers are used for dual carb conversions due to the lack of that nipple.
(borrowed photo from jrhone's old for sale ad)
post-33536-0-89362100-1429653256_thumb.j
My '76's divider has an extra boss that could be drilled for a second sensor.  Maybe you could find one like that and drill/tap it?
069.thumb.JPG.7b5eb0af7f8211b27d8abc11cb690a30.JPG068.thumb.JPG.9668661049d6c4614d52342df75ff75b.JPG
Maybe you could change the title of your ad to 1976 water divider wanted ?
(although I don't know whether they were all like mine)
Or, I do have an e21 divider and I could weld a nipple onto the side of it (and put it in a box with that air cleaner).
I used these little calipers to measure the nipple on mine and could drill out this 5/8" rod, or make a slightly longer one by turning down the chunk of 1" stock in the photo; which would also allow for a ridge at the end.
I forget which type of fuel pump you have, but if it is the stubby style, I could angle the nipple down a little, to help with hose/pump clearance.
We should probably switch to emailing now ...
3 minutes ago, Bibm5 said:
Would this work for you? b7aef4093145b44998a67c7131ab3309.jpgd4e2d802dac778ecfac3ec47e4dac035.jpg16983c774617e1ad9931354c5779aa9b.jpg
Sent from my SM-G960U using Tapatalk
Thanks Bib, but I think it will not. I need the small hose port for the intake coolant line opposite the two large ports.
Thanks for the effort!
Cheers,
Ray
This is the part you need:  https://www.ecstuning.com/b-genuine-bmw-parts/flange/11531261528/  and it is only 70 bucks.
The e21 efi version that Jim has is now NLA I believe.  Looks like BMW is replacing it with the e30 version, 11531274009
Here's the e21 and e30 versions.
BMWCCA  Member #14493
www.2002sonly.com
I think you had better change the title of this WTB ad Ray.
Perhaps, WTB '76 water divider (?)
If they were all like mine, you could just drill and tap that extra boss.
EDIT: now I see the one in Hal's link.  Perfecto!
(and from your favorite supplier!)
ES#24560 - 11531261528 - Coolant Flange - Directs coolant from the motor to the thermostat, includes mounting bung for temperature sensor. - Genuine BMW - BMW
Edited by '76mintgrün'02
