Rear quarter window hinges
Flamingo 5
Just pull.  It's held in by the pin, and the rubber sticks to the glass and the channel.
Heat might help.
If someone's left their quarter windows open, you can steal them by pulling the pin,
unscrewing the latch nut, and then pulling the window backwards.
It takes exactly a pair of needle nose pliers.
feloniously
  • Haha 1
There comes a point in every job where no amount of internet can solve your problem.
The rubber channel sticks to the glass and the metal, that's all there is to it.  And it sticks pretty well.
I said to try heat to soften the rubber.
I don't see any indication you did.
Chemicals aren't going to help much- it's sealed on there.
Beyond that, IF you got the cotter pin out,
it's a mechanical bond.  That's all there is to it.
I often end up destroying the rubber, these days.  It's been together 40- odd years, now.
It's up to you to defeat it.  Go at it!  It'll come apart.  Eventually.  With YOUR persistence.
no internet required
  • Like 3
Early cars had rivet in metal to glass channel, I drilled it out.Heat ? It was 90 degrees yesterday.
internet search revealed a marine
caulk remover called “De-Bonder”
and epoxy paint remover to desolve neoprene
ill let you know how it works
