Early half shaft grease fitting size ?
Flamingo 5
You mean the Zerk fitting in the joint? RealOEM lists that as M8x1 thread (as it lists the threads for all threaded parts /hardware).
And the part number is http://www.realoem.com/bmw/enUS/part?id=2552-USA-02-1968-114-BMW-2002&mg=33&sg=25&diagId=33_0880&q=07119960640
You are welcome!
You are welcome!
Thanks for your reply
the reason I didn’t need the part number? Just the size was because I wanted to call around and locate localylocals
And M8 x 1 is a "fine thread" pitch for 8mm diameter.  Normal thread  pitch for an 8mm bolt is 1.25 mm.  May take a little searching, but they're out there.  The head studs on my model 500B Fiat Topolino are 8 x 1.25 where they screw into the block, and 8 x 1.0 for the nut end.  Go figure.  Even the French use the same threads on both ends of their studs!
PS--The only 8 x 1.0 bolt I know of on a 2002 is the drain plug on the radiator lower tank.
Edited by mike
