Feels like popping the clutch as a kid
All ignition parts replaced all wires too
All dizzy cap roter and condenser
Timing good
Suddenly after three hundred miles or so in first gear it hopps like ones kid let the clutch out too fast in second and third at low rpm same at higher rpm not
I haven't a clue
Watched you tube video on how to determine clutch slipping but I don't know
Seeking help
Mark Baum / mbaum.collects@gmail.com
1976 BMW 2002 sunroof  (looking good now!)
2015 VW Jetta S (more like a car not a family boat)
Difficult shifting recently like the gates are not where they were prior if you will
Is shifter loose and all sloppy and the trans not getting full gear engaged?
You broken your drvers' side motor mount.
Try letting the clutch out with the hood open- watch
the engine to see if it hops out of the bay...
9 hours ago, TobyB said:
You broke your drivers' side motor mount.
Or if you have an early car (pre 1971), the right side motor mount bracket itself may be cracked/broken.  Early brackets are a single piece of bent-over metal and stress fracture.  Later ones are welded up and much sturdier.
We definitely need some more information to diagnose.
To test your mounts as Toby recommends, it isn't about reving, it's about applying a load.
Have your foot on the brake and let out the clutch a little so that it wants to stall the motor. If the motor doesn't move dramatically, then that isn't your problem.
questioning effectiveness of communication, here.
MB, at a stop with the car in 1st and the hood open,
and a safe amount of room in front of you,
try to drive away with the emergency brake pulled.
This will 100% rule out what's happened to me twice now.
Your initial description of what's happening makes it a likely possibility.
