M10 2002 engine block wanted
Brakey
Looking for a good 2.0 L engine block that hasn't been bored to the max +1.
Must not have rusty bores. Must be bored to no larger than +.5. Will take a complete engine but I need to inspect and measure the bore size.
I have 2 engines, 1 @90mm with a weeping/rotten head caused enough rust that the pits will require a cylinder liner.
The other had sit outside in the rain and had rusty bores. That one is at +.5 and its at the machine shop going to be bored out to 90mm. Not sure if it will clean up so I need a spare.
I'm located in Southern Michigan and will travel to pick it up. We frequently travel south on I 75 to Florida so one located in in that general vicinity is no problem.
Thanks in advance
