4-speed
ryanreddy
Hello, Ryan -
I have two 4 speeds, one that I payed $40.00 for and the other was given to me by an faq member.
I don't know the working condition of either, as I rebuilt my original. You're welcome to them, but you'll need to pick them up in Fresno.
FYI - My 75 was noisy, also.  I took it apart and found the problem was the older original lay-shaft bearing had gone bad. My shifting forks were all within spec, so I replaced all bearings and upgraded the lays-shaft berg to the improved roller bearing. It shifts very nicely now and is quiet.
Additionally, Popping-out  of gear can also be caused by flexing as a result of: worn-out center support, Guibo, or shift bracket bushings etc. So be sure to give those areas attention when you replace the trans.
Eric
1975 BMW-2002, Sahara (4-Spd)
