driveshaft balancing
PatAllen
Lord adhesive 406 is a two part adhesive used as a welding replacement in automotive and motorsports industries. It’s lighter than welding but I’m not sure how you would measure the weight of the adhesive itself, it would work to attack metal weights without heat distortion though. It sets very quickly.
if there is excess of weight then the metal can still be drilled/buffed to compensate.
i was looking also at some CV boot clamps. they are much smaller and subtle.
i would so like to find miniature, very narrow, hose clamp alike
1985 XR4TI, 22psi ±300hp
yes i saw them, its regular cv boot clamps, problem is that they dont offer a lot of inbalance to play with compared to hose clamps.
it might be good only to hold a piece of weight specifically id say.
found out that PANDUIT makes aluminium tie wraps with a stainless steel head.....
i have ordered few and will try them
Quote
Other Problem, most flanges and mounts on the car itself has tolerances that are way off
YES!!!
Or they get bent, misdrilled, etc.  I chased the flange on the 4.44 diff for MONTHS before I figured out it was one part of the problem.
Likewise, if the transmission is dropped on its output shaft, the shaft itself can bend.  Not as big a danger in a BMW
transmission, but in the Nismo version, it's got 18" after the intermediate bearing.  So a small bend in that shaft
leads to a very waggling flange.
It all adds up...
5 hours ago, TobyB said:
YES!!!
believe me it doesnt take a lot to compromise completely the balancing of a DS....0,010" and you can feel it, especialy if the DS is not well balanced to start with.
