Watch those 123 clips!
7502
5 hours ago, 7502 said:
Made some plug wire straps together using pipe hanger covered in two layers of old inner tubes. Not convinced it will handle the heat though. This is a trial run, might have to order some pre made ones.
Beautiful. It will work for a long time. If the coil wire has plenty of slack (looks likely), the wires won't be your problem.
Jerry
Jerry
no bimmer, for now
Now you need an E30 exhaust gasket to keep some of the heat off the wires.
I have actually made something to bolt to the top of the manifold instead, because I figured
it was easier than taking the manifold off...
...which turned out to be true, on that engine.
Maybe I'll try some of those fiberglass boots for the time being, what's the worst that can happen?
BTW- Chirped the tires pretty good and made it through the intersection this afternoon.
Edited by 7502
