will not idle
Moto Carlo
Attached is a photo of the egr location I found in a supplemental owners manual I in the glove box.
But I am not sure where on the car I would see it, if it is still there.
But in terms of the thermal reactor, is that the mysterious cast iron piece I see over the exhaust manifold?
Photo (I took it off and hit it with some engine paint just to clean it up. It  is under the plug wires.
I am sure all the emissions stuff has been removed by now, but still wondering about the engine itself.
Does anyone know of any engine modes for California ?
I ask because  when I ordered the single side draft Weber from Performance, Steve asked if it was a Ca car or a 49 state car , so he would get the jetting correct. Hummm?
Perhaps we should start a separate thread for the California vs 49 state cars.
Thanks to everyone for chiming in.
No.  That is an aluminum heat shield to protect the plug wires.
The thermal reactor was a much larger version of the exhaust manifold.  That photo helps.  You don't have a reactor manifold.
You are running points now.  What is the current dwell setting?
Do you have a variable advance timing light?
OK. I have idle. Wahoo.
I put a fuel pressure regulator on the gas line and set it a 2.5 psi. Then took the float off the Weber. Sure enough it was set a 20mm. It is supposed to be 12mm (Some people push it as far as 15mm, but not 20). Doing those two things , now the car idles on it's own, and I am calling it a win.  ?
When I can get back to it, I will time it properly. Then go back to the carb adjustments.
I also have a AFR gauge on the way. That was a good idea, and it should really help me get the jetting right.
I simply wanted to do a follow up to this thread .
I appreciate all the help once again. I hope I can contribute along the way.
All the best.
