Hood Support Identity
We have replacement hood for my 73.  (Old hood had some light collision damage but the  'oil canning' was significant.)  The new hood did not have the support mechanism, so we are moving the one from my old hood to the replacement.  Ran into a PO situation.  The four bolts that secure the sprung bar to the inner sides are designated in the parts guide as M6X16-SB.  These appear to be a fine thread.  It appears that on my old hood, PO had used other 6mm fasteners including one body screw and probably stripped blind nuts on the old hood.  It appears that the M6 - 1.00 thread was not correct.  I have ordered the correct bolts from Maximillian as they do not appear to be easy to source.  I would like to have a thread tap on hand for this, so I need the correct thread.  Can someone identify the thread from M6 x 16 - SB?
Edited by David Layton
Frau Blucher - 73 tii
Captain Biggles - 66 Triumph TR4a
You might try chasing the threads on those blind nuts with a 6 x1 tap.  If that doesn't work, you might drill out and re-tap for a 7 x 1 bolt; there should be enough meat on the nut plate to accommodate the extra millimeter.  6 x 1 bolt size is the metric equivalent of a 1/4" x 20 SAE thread so is very common.  Don't think I've ever encountered a 6 x .75 thread bolt on a 2002...
