EXHAUST LEAK HELPPPP!!
Akul2002
18 hours ago, Akul2002 said:
I can feel the air coming from that hole!
If the hole is thru the manifold, you would need to wear asbestos gloves.  It would fry anything nearby.  At idle the exhaust is about 600F and running hard 1000-1200F
Well that hole is too far down towards the back of the mani to be a heat shield bolt. I would try to work a mirror behind that area check for cracks.
George S Patton
20 hours ago, Akul2002 said:
I was driving heard a metal clunk and started to make a ticking noise, I can feel the air coming from that hole! is there supposed to a bolt there?
Assume the metal clunk you heard was whatever a PO had attached there (welded/threaded) falling off.
If the hole is threaded you can fix it with a bolt, if not, some welding required.
Les
'74 '02 - Jade Touring (RHD)
'76 '02 - Delk's "Da Beater"
FAQ Member #17
