Differences in Stick shifts
bwint313
The only way to verify the type of linkage connection is by physically looking. There were two versions it might have been changed. without tearing everything apart, you could perform maintenance by removing those two trans case bolts cleaning out the bores with brake cleaner etc...replacing the shift plate bushings and shifter rod bushings this was a common cause for the slop.  Those two allen bolts like to back out due to engine vibrations out of the transmission case so use a locktite product to prevent recurrence. Check and tighten other bracketry with loose fasteners in that area. To keep you rolling, you could just snug everything up til you are ready for a decent rebuild with all necessary parts. Realoem.com under sedan will get you the actual part numbers for the common items. There are various bushing upgrades that you can use alternately from the various vendors on the web that specialize with 2002s. Good luck!
https://www.wallothnesch.com/media/catalog/cache/6_2317_800_564.webp
https://www.wallothnesch.com/media/catalog/cache/6_2316_800_564.webp
The late version is shown first then the early version second.
Edited by Mikesmalaga72
add
