WTB Early Vinyl / blue / 1970 O2 / front repair / FOUND IT !
paulcain
This material has been sourced. Thank you for the replies.
WTB  a piece of this blue OEM Vinyl in the early pattern as shown below in Blue.  We need enough to cover one front seat bottom.  Willing to purchase a rear seat back / bottom to harvest enough material.  text at  949 375 5975 or email  mrpcain@gmail.com
Thank you,
Paul Cain
Edited by paulcain
updated content
On 9/4/2020 at 12:18 AM, Mikepelly said:
Paul is selling nice material but it's not the same if you need the early style with the heat seams
+1
Duplicating the heat seams is what no one is (yet) doing. You can match the perforated vinyl closely, and you can create the pleats with real stitching, but the original heat seaming, in the style used from 1966 through most of 1971 created a flat-bottom valley between the pleats with a single row of “stitching” molded in vinyl!
If you need that level of original appearance, you’re left looking for original perforated vinyl you can swap into your seat. Hint: don’t worry about color of the replacement original vinyl: dye will work wonders!
