Freshly rebuilt M10 engine for sale
Steve570GT
Price: $3900
Description:
Just completed rebuild on this M10 engine. Has not been run. Had been installed in my 1969 1600, and ran well. had a different engine for this particular car, so just decided to rebuild this one and sell it. Serial number of the block is 1457125. This corresponds to a 1967 2000TILUX. Block date shows a March 1967 casting date. New Mahle Bathtub pistons 10.5 CR. 89.97mm ( 2nd oversize). Rods checked for size and re bushed. Block tanked and bored to 1mm over.  121T head completely rebuilt with new valves and guides and stem seals.. Head surfaced along with upper timing chain cover. Crankshaft polished and remains in spec and standard size. Stock camshaft.  New main and rod bearings. New E21 oil pump with original pick up. Later style single nut oil pump sprocket. New timing and oil pump chains. New chain ramps. New water pump. Included with engine is freshly resurfaced flywheel (six bolt). All new gaskets and seals including front and rear main seals. Various other parts included with sale such as intake manifold, distributor and solex carb. Will deliver in Colorado for free, $300 elsewhere in the continental US.
2 hours ago, Guest_anonymous said:
No step on the flywheel, is the 6 bolt crank spec for the pressure plate different?
Not really sure. There are pressure plates and clutches that will fit the older style six bolt crank/flywheel that are available. Believe they are 228 mm
The car (1457125) was for sale (on consignment) with autokennel, Costa Mesa, Ca, a year ago. Tel # 714 410 0223.
It's possible the Owner/new Owner might be interested in having the original motor.
Edited by 02Les
  • 3 months later...
Actually the original flywheel is on my 1600, this is just a spare flywheel that I purchased on eBay. It was only when I received it that I noticed it had been machined enough to eliminate the step. The six bolts are tough enough to find that I just kept it. If a buyer already has the six bolt set up, that’s great, but if not I know there’s a company that makes a conversion kit for about 500 bucks.
  • 1 year later...
