1976 BMW 2002 Automatic
RoundieAJ
On 11/6/2020 at 6:42 PM, LindrelT said:
... The trans tunnel is already wider right?  Thx!
Yes, but that’s not a particularly big deal. The difference is minor. I suspect — never having personally converted an automatic to an e21 overdrive 5-speed — it might be easier to start with a manual and give its tunnel a couple good whacks to accommodate the 5-speed.
I did the swap from auto to five sp last winter using the Blunt basic kit and Steve's excellent driveshaft. EBay for the other manual bits. Cost was approximately $ 1800 in parts excluding the transmission. The wider tunnel definitely helps.  If you have a four speed and can reuse the clutch, pressure plate, clutch cylinders, pedal box, console shifter etc it is a lot less expensive. The auto to manual swap can add up dollar wise.
42 minutes ago, resra said:
What color is that? I dont recall a 2002 brown in that shade. Nonetheless a very good price.
The trunk pic is the give-away. Originally Sienabraun, it has had a repaint in a slightly brighter off-shade.
  • 3 weeks later...
