What are your plans for your 2002 for 2021?
Vicleonardo1
23 hours ago, NYNick said:
haha! Truthfully, I am only partially sold on the name. The other front runner is "Earl" which is also good and is the name written in the owner's manual with a phone number! I haven't called that number yet...
Edited by popovm
Since it's always good to have goals in front of you, I have the same goal from 2019, 2020 and forecasted 2022....get my car painted.
Life has gotten in the way raisin youngins with all their pre-pandemic activities, now they're a bit older and things have slowed down, but unfortunately work is getting in the way.  Guess I don't want to look back after they're all growed up, and wish I would a spent more time focusing on the car, right?
  • Like 4
My 2020 BMW Goals
1. 3.64 LSD
2. Sidedraft DCOE 40s conversion
3. New Rear bumper and rear panel repair
4. Oil pan and front cover leaks fix
5. Door panels update
6. Recaro seats recover
7. Wheel Bearings
8. Brake Job
9. Laguna Seca Track Day
10. Paint and refurb my extra BBS wheels
Number 1 already done.
2018 BMW M550i X-Drive
1964 Volvo Amazon Wagon
http://www.project2002.com
3 hours ago, jrhone said:
My 2020 BMW Goals
1. 3.64 LSD
7. Wheel Bearings
8. Brake Job
Do you mean 2021? Or is this tongue in cheek ?
Good list regardless!
  • Haha 1
1973 2002tii (2764167), Baikal, Rebuild blog here!
--> Blog: Repro tii cold start relay;   + --> Need an Alpina A4 tuning guide? PM me!
I plan to do everything I possibly can in 2021. It all comes down to what is & isn't cancelled or postponed.
  • Like 3
Andrew Wilson
2020 was a big year so 2021 will just be a few projects .
1.  Fitting some Yokahama AD021r tyres 185-70-13 (currently in transit from Ireland to Australia).
2.  Relocating the battery to tge trunk.
3.  Possibly doing a plenum & cold air intake for the webers.
4.  Hopefully some E24 rear seats will come my way.
1974 2002 2.2stroker, DCOE45's, 300deg cam, 5 spd, 3.91 LSD // 1984 E24 M635csi, dogleg 5spd 3.23 LSD. // 1994 E34 540i, supercharged 16psi, 6spd E85 only, 3.15 LSD // 1997 E36 M3 Evo, low comp supercharged 18psi 6spd (under construction)
Couple of electrical gremlins involving the hazard switch need attention. Hard to drive without directionals
Edited by Mike A
73 Tii stock build, Porsche Macan   , E46 330i Florida driver,
….and like most of us, way too many (maybe 30 at last count) I wish I hadn't sold ?
Haha...nice catch.  Maybe that was subliminal....alot of that was on the list in 2020 as well.
I accomplished a lot on my car in 2020, and I have quite a list going for 2021.....here are a few of the top items from my 2021 list:
  • Install new rotors & repack wheel bearings (Done)
  • Install Bilstein Front Strut Inserts (Done)
  • Install 5 speed with lightened Flywheel (I have all the components, just need to get time in the garage)
  • Install AFR Gauge in the seatbelt indicator pod
  • Install Header
  • Figure out which exhaust system to go with (I have a stock system, I have an IE system, and I have a Supersprint muffler with the dual tips)... the stock and IE leave a bit to be desired sound wise, but I actually think the IE is quiet because of the resonator design and would actually sound better with the stock resonator attached (I tried it in the garage). The Supersprint sounds great but I am having trouble getting it to line up properly, and the mounts need to be modified because it is set up for an early car.
That is part of the list... I guess I need to get to the garage ?
On 2/6/2021 at 1:36 PM, uai said:
Rosejoints for Suspension front inner LCA and Front Rod  as well as rosejoints for the rear.
I was lucky enough to attend a race car seminar with Claude Rouelle years ago.  He told a story about replacing all the bushings on the car with rose joints.  Worth every penny and every hour of work to do it.  Said you could see the difference in the handling from the stands.
Dave.
