Wiring for euro plate lights??
Highnote1
What am I missing here? Two grounds joined together and two positives joined together to plug into plugs in trunk. Keeps blowing fuse 8. I am no electrical expert but thought this was right. Any help appreciated! Led bulbs so should not be blowing the fuse load wise.
Have you run a wire from the negative battery terminal to one side & positive from the other side with bumper as ground?
I usually bench test with a battery charger first.
Andrew Wilson
Incandescents are inexpensive.
Andrew Wilson
1 hour ago, Highnote1 said:
It would be just perfect if I just happened to put both of them in wrong! ?
There's something to be said about the original bulbs!!
As Esty said, the screws that hold the lamp assy to the bumper act as ground/earth. Power from 'green-red' wire in the trunk that lit up your USA lights before.
Les
'74 '02 - Jade Touring (RHD)
'76 '02 - Delk's "Da Beater"
FAQ Member #17
