WTB AC compressor bracket for early M10 block
skyking96w
I know this is a long shot.  My M10 block is a very early casting without the mounting lugs for an AC compressor.  I have a compressor bracket that either came for Clardy and/or was fabricated to use some of the front cover or water pump bolts as mounting locations.  It has broken, and the shop I use is not sure they can repair it.  Looking for a replacement, or maybe a York bracket that can be modified.
1971 Alpina 2002
=00=
Fixing your broken mount — which you know worked — is probably a good idea. But you might want to check with Blunttech, to see if their version of compressor mount might work on these early M10 blocks. It’s a very sleek design, quite different from the traditional compressor mounts.
