Roundie Front Bumper Grommets Which Way?
goofycarp
IIRC they're symmetrical, so they should work either way.  But it's been a long time since I installed one, so if they're not...remember that the nose panel is slanted and the bracket is parallel to the ground, so you should install 'em so the opening that the bracket passes through is as vertical as possible.
this was a timely thread
installed fresh today.
Cleaning the grommet's groove of loose, rubber-casting swarf helped with the fit - that plus Sil-Glyde.
Edited by ScottA
machinist - A&P - UAV inspector.
'71 1600 parts car, '71 Nevada tii tribute, '73 Polaris automatic in assembly awaiting 5-speed, 3.90 LS and dual 40s
'61 R27 - '74 R90S - '83 R100RS
