back of ignition switch wire plug
esty
i took the wired plug off the back of the ignition barrel...tried turning it with a screwdriver and got some resistance...i sprayed some lube in it tried again, it turned back and forth a couple of times and hung again with a the end of an inner spring sticking out one of the holes the spring loaded bearing stops in...looks like i need a new plug...it turns freely now but i believe the spring i pulled out is what kicks the switch back from the run position
does anyone have the rear wire plug for the ignition switch
null
