Hey Daniel Cooper
...very much for posting this! I will definitely be at this years Fest West and would sooner miss my wedding...I cried when I missed the last one (my first since moving to CA from NY) on account of my car being "down" after I sheered a trailing arm off the subframe powering out of a hairpin on Twin Peaks...
Love ya'll
Coop
Matt, I am shamefully clueless on how to post pictures on the board and would welcome anyone's advice on how to do so! Some day, I'm hoping to do a site for the car. In the meantime, I will e-mail you a couple of pics that I have and feel free to post them yourself. As far as specs, here is what I have done to date (sorry if it's too comprehensive!) and what I still plan to do:
Car: '73 2002 sunroof tii (2764282)
-Paint: Baltic Blau Metallic (Glasurit 54-line)
-Early Euro Bumpers (2002 AD)
-Euro F turn signals
-rolled front fender lips/shaved rears
Interior
-Recaro SRD Front Seats in Tan Monza Cloth
-Ireland Anodized Aluminum center gauge panel
-AGLA shift/E-brake boots
-Preferred Broken Clock/Cracked Dash package
-S14 Motorsport Stereo under hood
Engine: 1991 M3 (S14)
-Stroked to 2.5L by MASR (Dyno'd pre-header at 255hp)
-extensive headwork
-MASR spec cams
-Big valves
-2 pc Gruppe A header
-MASR One-off 3" Stainless exhaust w/2 Borla mufflers
-TMS 8lb Aluminum Flywheel
-M3 Oil Cooler w/braided lines
-320i Radiator
-Baffled oil pan
Transmission etc.
-CR 5-speed from Euro 323i (soon to be Blantonized)
-Reference sensors for S14 Mill welded on by MASR
-Star Kevlar Clutch Disk and L/W Pressure Plate
-UUC Short Shift Kit
Differential
-Quaiffe LSD in 3 series case built by Ireland Engin.
-3:64 final drive ratio
Suspension
-Ireland Engineering Coilovers all around
-Springs (F/R): 250lbs/200lbs
-Ireland Camber Plates
-ST Bars 22F/19R (may replace with Ireland's hollows)
-Urethane bushings throughout
-Semi-Solid rear Crossmember bushings
-Subframe and Trailing arms gusseted by Bill Arnold
-One off stainless Fr. tower brace w/engine tie-in
-TEP Rear tower brace w/battery relocator
Brakes
Front (Built by KVR in Ottowa)
-AP Racing Billet calipers
-2-pc Rotors: vented/drilled w/anodized alum. hats
-KVR pads
-Braided lines
Rear: 323i big brake conversion
Wheels/Tires
-6.5 X 15" HRE 535 Forged 3-pc wheels (15 lbs each)
-Bridgestone RE730 tires: 205/50/15
Here's what I still plan to do as I can afford it:
-Custom Fully welded in cage tying all 4 strut towers together yet maintaining sunroof and rear seat
-KVR/AP Racing Rear Disc Conversion
-Big bore (48mm) throttle bodies. I'll have mine enlarged as the real Motorsport ones are too pricey
-Cold Air Box for K & N Filter
-Custom Aluminum Radiator
-Carbon Fiber hood, trunk lid, front fenders
-CR Steering Box
-6 Series Rear Seat finished in Recaro Tan Monza Cloth and customized to fit around roll cage
-Dash reupholstered once it is cut to clear roll cage
Well, thanks for your patience in reading this. Unless I'm spacing on something, I think that pretty much sums up the lunacy that has consumed me for the last ten years and, no doubt, will continue to do so until I am taken to either the asylum or the poorhouse...
COOP
IMG posting tutorial:
1. first we need to upload img to a web server. You may have some web space with your ISP or you may use a picture service like photopoint or yahoo pictures. I personally use fototime as I believe it offers a very flexible platform and makes posting pictures a no brainer. The only drawback is that it cost around $25 yr, but for that price you get 250MB of space.
Most of the picture sites offer an easy way to upload. Ussually you follow a picture upload link, it then offers you a browse button. When you click on this one a box will appear. It offers you a way to look for the picture file in your computer. Once you find it click open, the file should now appear on the box next to the browse button. Now you just upload or submit.
Once you have your img on a web server you are ready to post.
2. the easy way to post to the board is to use the optional img url box to enter your pictures url. **The url is basically your pictures address and this is what is use to post the picture to the board. In essense you will just be placing a reference of where the picture lives. THe best way to get your pictures url is to bring it up on your browser (of course using the online web server and not your own Hard drive) and then right click on it. After rt clicking click on properties, a info box will appear. In it you will see a line for address (URL). Copy this url and place it in the optional img box and submit your post.
to post without using the box or to post multiple images you will have to write some simple html code. for a single img use the following:
The URL goes in here
EX:
By using the above code you should get something like the following
I obtained the url by rt clicking on the img.
for multiple images you just do it over like the next example:
by using the above you would get somthing like the following:
you should be able to just copy any of the above examples or the following:
and replace the URL with your own to post your pictures.
I hope this helps
.._____
/orig.gif___orig.gif\
[O=00=O]
CLICK FOR BIMMER STUFF
More STUFF
did i say that right? if not, I'll say it again. HOLY CRAP!!!
Daniel..your car is pretty much EXACTLY what I would envision mine as..if I had the cash to do it. Unfortunately.. I spend my money on way to many stupid things :).
One question, who is KVR, MASR and/or AP?
thx
Matt
