Rubber seals install
I just did my trunk gasket with Wurth AdhesiveFlex Urethane Seam Sealer. With that I had a can of 3M Adhesive tar &wax remover. The Wurth went on nice. It comes in a tube and you must use a caulking gun. Best control that way. I took some solvent and cleaned both the metal surface and the gasket for best adhesion. Also had a bunch of small rags to clean up squeeze-out and me with 3M. Once cured, if you want the gaskets to look really good go to the drug store and get some glycerin. dilute it about 10-1 and apply to to gasket. works great
