Will a tii dashboard fit a 1976 2002?
VietCat
Yes of course, they are identical and in fact all dashes have a cutout on the backside for a clock which is simply covered on standard models.
FYI all tii dashboards have a center clock mounted on them; that’s their distinguishing feature…
'74 Sahara/Beige 2002 HS car, long, long ago...
'73 Polaris/Navy 2002 tii lost to Canada
'73 Malaga/Saddle 2002 current project
'73 Taiga/Black 2002 tii in my dreams
To bust another myth.............not all dashboards had a 'covered' cut-out. Below picks of two one-piece dashes, first is a Euro and the second a USA.
However, as you say, they will all fit.
Les
'74 '02 - Jade Touring (RHD)
'76 '02 - Delk's "Da Beater"
FAQ Member #17
So, its not entirely one size fits all because......... there were three main different styles of dash. The early three piece, the 72, 73 two piece and 74-76 one piece dash and each one of those different designs had different mounting points behind the dash. So, hardest is to fit a three piece dash on a one piece dash car or a one piece dash on to a three piece dash car. Mounting points are way off. Also you will run into the heater cable length issue. Safe to say that the mid point 72-73 dash can take the one piece 74-76 dash (still requires drilling new holes etc.).
Yes the outside dimensions are all within mm of difference. but.....its a pain otherwise tii or not.
Edited by resra
heater control styles vary, too.
There are at least 3 types of early (3 piece) dashes,
only 1 2- piece version that I've seen,
and at least 2 one- piece.
They can all be made to work on different cars,
but the amount of fettling varies from drilling a few
holes to switching your heater box.
I have the one piece dashboard, like the one pictured above by Chargin, so hopefully this tweaker doesn't have to tweak it too much.
I was able to swap a 1 piece dash into my early 68 car instead of it's original 3 piece...  I ignored the two screws at the top near the windshield (they would retain it there instead of the clips in square holes on the 3 piece dash).  I had to use older heater controls- the lighted 4-slider setup for a one piece dash will not work with the car's sheet metal under the dashboard even though the metal facia plates are the same size. (I mounted a rotary fan speed switch in the binnacle where it said "rear defroster") I had to use the original glove box because the mechanics are different- again the sheet metal under the dashboard dictates what will work.  The other screw holes in the dashboard a  matched well enough to work.  My one piece did not have the clock hole, but I don't think that's significant
The hole is in the metal under the foam.  My dash looked the same and was pretty nerve racking cutting into it for my clock but then I found the hole in the metal and all was well.  Now my 69 has a clock!
Chamonix 2002tii 2782507 July 23rd, 1974
Granada 2002 1664158 November 28th, 1968
Malaga 2002 4223965  March 11th, 1974 - Sold
You'll Never Drive Alone!  #YNDA
Yes, that’s what I meant-
