Shift-rod joint pin problems
Steve76063
Go to solution Solved by bergie33,
51 minutes ago, Steve76063 said:
I guess it's time to go OEM.
If the new one does not come with the little foam bumper inside, dig the one out from the MTC unit and use it. Or simply cut off a slice from a foam earplug.
76 2002 Survivor
71 2002 Franzi
85 318i  Doris
  • 3 weeks later...
Just thought I'd update this thread...an OEM joint and pin fit perfectly :)  The only "issue" was in getting the foam insert to compress enough to get the pin in.  Once I got it started, I could push up on the joint a bit to straighten it out and the pin slid in no problem.
Bottom line: OEM worked for me (although is much more expensive than aftermarket)
S/N 2579886 Inka (Code 022) Birthday 03 Dec 1971 Delivered 13 Dec 1971 to Hoffman Motors 40 DCOE's, 9.5CR, 123 Ignition
