+0.25mm 89.22 E12 Pistons
tonylsmith
Hello!
Looking for some +0.25mm pistons and rings
I have an original block, e12 '75 head, and 2L crank.
No preference on CR. Primary focus has been getting this thing on the road after sitting for 35 yrs.
I have a set of +0.5mm flat tops lying around but I'd prefer not to skip an oversize if I can help it.
Thank you!
Tony
Edited by tonylsmith
  • tonylsmith changed the title to +0.25mm 89.22 E12 Flat Top Pistons
Tony,
Double check that you have an E12 head — which is what all ‘75’s originally had. I say this only because so many members type “E12” when they mean “E21,” and vice versa. And flat-top pistons are, indeed, often associated with the type E21 head, which was the standard issue on U.S.-bound 49-state ‘76 2002’s. Type E12 heads, on the other hand, accommodate piano-top pistons.
And a type E12 head — regardless of the year, since they’re all the same — permits a wide range of compression ratios, from 8.1 to 9.5, with increasing heights to the piano tops. I believe the U.S. ‘75 models were originally equipped with 8.3 pistons. Pick your compression and start looking. If you’re looking for NOS examples, the price increases with the compression ratio!
Below are photos of some of the E12 piston options: 8.1, 8.3, and 9.5, respectively. I don’t own these pistons; I just have photos of them!
Good luck and regards,
  • tonylsmith changed the title to +0.25mm 89.22 E12 Pistons
And… Tony, don’t turn down second oversize pistons (approximately 89.47 mm.), particularly if you’re looking for higher compression pistons, e.g., 9.0 or higher.
I agree that we should save our engine blocks for future rebuilds. But if you can’t locate first oversize pistons, you could probably be forgiven by the vintage car gods if you needed to use second oversize. I am assuming that a machine shop has already measured your bores and is confident a first oversize re-bore will be sufficient. If a machine shop — or equivalent — hasn’t yet weighed in on the condition of your bores, that needs to happen before you go piston shopping.
If the.5 OS flat tops are new, complete..? Consider using them.  Pistons have become as rare as hens teeth. Looking to score a new set from private sellers can take a long, very long time.
9.5 CR bath tubs are still available at WN if you wish to spend almost $300 a piece
Dont buy used, its pointless.   Good luck
76 2002 Survivor
71 2002 Franzi
85 318i  Doris
+1
A flat-top piston with an E12 head is going to be less than an 8.1 compression ratio (since there’s a very shallow piano-top piston that’s rated as 8.1). That said, “less than 8.1” is likely in the 7.9 to 8.0 range, so it’s probably an imperceptible difference. (Those 9.5 bathtubs probably won’t work with his E12 head.)
Best regards,
$241.40 each without VAT, so $1000 for a set of 4.
