How hard should it be to put drum back on.
On 6/4/2022 at 6:43 PM, Mike Self said:
Trick on freeing stuck adjusters:  instead of rounding off the adjuster heads or boogering 'em up with visegrips, pull off the shoes (I know, then you'll have to wrestle with the bitch W spring), spray plenty of penetrating oil on both sides of the adjuster, and grab the inside peg with a pair of vise grips.  Work it back and forth until it turns freely, wipe off the excess penetrating oil and reassemble.
If the adjuster is really stuck, tickle it with a propane torch, but be sure and (1) shield the wheel cylinder and (2) have at least a wet rag handy in case some flames appear.
PS--someone on the board was offering thin box wrenches made especially for those adjusters...
Roger that. I knew about this but pretty sure it was from you from a previous post! Thank you, I appreciate that you continue to share the knowledge with us newbs. It’s gotta feel repetitive sometimes!
Edited by popovm
