Getrag 245 Clutch Pivot Pin Install Question
bergie33
It should lie flush
I doubt it would crack the aluminum, the pin will smush first.
Got a little brush you can clean out the hole with?
heat the aluminum a bit with a heat gun?
a bit of petrolatum on the shaft?  Don’t start guys?
Edited by tech71
76 2002 Survivor
71 2002 Franzi
85 318i  Doris
37 minutes ago, tech71 said:
It should lie flush
Ok, well, thanks for the tip... I cleaned them heated the hole, turned a can of air upside down and sprayed the tip of the pivot to chill it, and hammered it in.... Gave it one too many hits and the tip broke off. ☹️
Time to order another one.
Karl B.
1974 2002tii Malaga ("Conrad") -->> Conrad's Restoration Blog
2003 330i ZHP 6-spd
2011 328i xDrive
Nooo.... not the brass pin thread again!!!
So, what I found was that a socket that fit over the top of the
pivot pin worked pretty well.  Don't be afraid to sand it down a bit-
it's NEVER going to see negative installation force.
  • Haha 2
Without reading prior posts on the brass pivot, I personally don't like the idea.  I would rather have the pivot wear than the clutch fork.  I have a new one on order from Blunt, which will be kept at room temp, well lubed, and inserted into a properly heated and cleaned hole in the transmission.
Karl B.
2003 330i ZHP 6-spd
2011 328i xDrive
I have to admit I know nothing about the brass pivot pin vs. the plastic one.  Sounded like a good idea to me, but what do I know?  I've stuck with 4-speeds on all of my cars...
'73tii Inka 🍊
'74tii Fjord 🏄‍♂️
