Scammer alert: "Rock Mathew"
Don Bower
10 hours ago, Don Bower said:
Jim:  The most innocuous, OCD parts on the car.  The exterior, aluminum trim piece running the length of the "longitudinals" (Porsche vernacular) is surrounded by 4 vinyl gaskets -- long ones on top and bottom, and very short, gray ones on the vertical leading and trailing edges.  About 2 inches long.  Usually lost whenever that trim is removed.  I need all 4 of the short ones (2 left and 2 right, but they're all the same).  BMW sells only sets for the whole trim piece at >$100.  I'm not that delusional.  Yet.
Don
Ah- the knee trim filler pieces!
Give it time, you will get there.
Need to confirm, are you referring  to these pieces?
I dont see replacement gaskets for those, can you share your info please? Thank you.
Another option is to Mcgyver some cheap, rubber J trim, takes a bit of time and careful trimming.works ok if the end pieces are still there,
Black-5M-J-Shape-Black-Waterproof-All-Seasons-Rubber-Car-Sedan-Boat-Door-Window-Edge-Protector.jpg
Edited by tech71
76 2002 Survivor
71 2002 Franzi
85 318i  Doris
25 minutes ago, John_in_VA said:
Don's referring to the small gray vinyl strips at the vertical front & rear edges of the stainless rocker panel trim.
Were there any there? There were front, middle, rear, along the top edge of the rocker panel in the parts manual that I know of.
Part nos 51 72 6 440 147 (FRONT), 148 (MIDDLE), 149 (REAR) or buy by the meter 51 11 1 807 884
2 minutes ago, John76 said:
These ?
Started off as gray, but they turned a bit yellowish after 46 years. (My hair did the opposite)
Could be worse...
Your hair could be NLA.
:D
  • Haha 1
Ray
18 hours ago, John76 said:
These ?
Bingo!  The unicorns have been identified.  Now all you concours judges have another source of point deductions.
Someone oughta reproduce those.
Isn't there similar that is supposed to be behind the early grilles?
Ray
A gray vacuum hose cut to length & split open could do the job.  The vinyl/rubber pieces that go between the bumpers & overriders may also work.
OVERRIDER SEAL IN SILVER:
https://www.jaymic.com/1502-to-2002-turbo/exterior-trim-seals/bumper-parts/overrider-seal-in-silver-71-each.html
Edited by John_in_VA
added parts source
John in VA
An AP story vis AOL claims that Zelle and other pay pal like scammers is owned by banks, offers no buyer protection and has a dismal record of clawing cash back for the victims.
I will stick with paypal no friends and family ever.
I learned the hard way. Trust me.
