Will E30 Style 5 Wheels Work
Fraidknots
Those wheels should fit, I think +25 offset is ideal for the '02s, so the ones you are looking at (ET+30) shouldn't be a problem. They are 6.5 inches wide too, so some room on the sides.
I have the E30 325IX wheels, which are 15x7 ET+41 offset, so I have a 20mm spacer to fill the side gap a little. Pics below, they're lowered on BavAuto springs and Koni shocks.
Edited by 72MetallicMalaga
'72 Metallic Malaga 2002 with a '73 M10 | Dual Weber DCOE 40s | E21 5spd and LSD | Pertronix II
Quote
.All non-M3 e30's were 4 lug. The iX also had 4 lug, but with the wrong offset for a 2002.
this.
E30 basketweaves fit.  They are kissing- close to the front struts, which means that some tires
rub- but also that a little spacer'll do you up nicely.
8 hours ago, Lorin said:
The ix E30 also were 4x100, my statement is correct.
i've been corrected.  First mistake I made all week :(
To be fair, you weren’t the only one here doubting my extensive E30 wheel knowledge.
Im on my second or third mistake this week, you got some catching up to do !
  • Like 3
I ran E30 style 5 basketweaves for years with no rubbing issues (195/60-14 tires) on my former tii before I moved up to 15X7 wheels.  One issue you need to be  aware of, the OEM center caps for the style 5 wheels are nearly $100 each.  If you lose one, it can be pricey.  I suggest you spend some time in this thread to learn from those who have been there and done.
Edited by Gordon
74 tii (many mods)
91 318i M42
07 4Runner
They are great wheels, OEM, very well made and look great, until you have to clean them and depending how clean you like them it could well drive you nuts😜
They are not fun to clean, that said a good power hose and wheel cleaner helps!
There is a mob called kleen wheelz, he makes dust shields that keep at least 90% of the brake dust off the wheel, unfortunately I got his very last 14” set, that said he did have 15”. They work, you can’t see them, they don’t make your brakes over heat even with “spirited” driving, in fact they work so well I’d consider baskervweaves again if I didn’t love my Octavos so much🙄
Edited by SydneyTii
I agree cleaning them is a nightmare, but Sonax wheel cleaner and a nice brush help make things a little easier!
Not bad for 40 year old wheels!
  • Like 4
6 hours ago, calw said:
 And there are many examples of E30 alloy `14" bottlecaps (not iX wheels) being used on 02's with good results, offset wise.
That’s what I’m doing. I got them as a long term temporary solution. Wanted 14” tires minimum for better selection. Running 195/50/14 Falken Azenis tires. This is as it sits with stock height suspension. That will change soon.
and yes, I painted them a darker color to hide imperfections lol. Copper inspired by M4 GTS wheels.
2003 e39 M5 (daily)
1986 e30 325es (sons car)
It will be a major score if you can find some open lug basketweaves,  then you don't have to deal with the big center caps.  These MSW 15X7 ET26 basketweaves are on my tii.  4X100 open lug weaves were made by numerous wheel manufacturers in a variety of sizes.
74 tii (many mods)
91 318i M42
07 4Runner
On 10/31/2022 at 6:49 AM, Fraidknots said:
 "Set of 4 oem style 5 basket weaves with original metal bbs center caps 14x6"
Caps are not metal,  they are plastic, expensive plastic as well.
74 tii (many mods)
91 318i M42
07 4Runner
