Auxilliary Gauge - Unusual Location
fjmarch
Some people hate this, I like mine.   Just food for thought.
WWW.KOOGLEWERKS.COM
designed to house two 52 mm (2-1/6”) standard gauges and replace the OE steering column top cover panel, made from molded 3/32” grained ABS plastic. This part installs with factory bolts, no cutting or drilling required. Comes with holes for gauges pre-drilled and threaded...
(Stock Photo)
"Goosed" 1975 BMW 2002
AFR in the Fasten Seatbelt pod
The rest under the Clardy
Started with a Kooglewerks version
A. M10 5 speed
B. F20c 6 speed
My first homemade version 6 years ago
Kooglewerks Non-AC for my second console
Hopefully my journey may be helpful 👍😉
  • Like 3
I don't take myself or opinions Seriously
My 4th 2002 and the first set of Square Tail-Lights
See the 4 versions of my 2002 project here: SoCal S2002 | Facebook
Chargin - Yep, all those console solutions look and work great for adding 2 or 3 gauges.  None are good for single gauge.  I would love to understand how you converted the FSB pod to AFR gauge.  Mine wouldn't be an AFR but a Oil Pressure but maybe the basics of your approach would be useful.  Thx.
 Maybe this is the opportunity to add a couple more gauges?
Here's my progression from stock ash tray w/ dealer installed AM radio.
3 gauges/ no ashtray/ hazard button moved to "manual choke" location.
3 gauges with ashtray (and hazard/rear fog buttons) and stereo.  Never had the nerve to cut holes anywhere for speakers!
Final setup (for now): 2 gauge (ammeter delete) plus clock, hazard button, original AM radio and speaker.
Green rear fog light button moved to manual choke location...closer to front fog light switch.
You could do a single gauge with the ashtray delete and still have the hazard and rear fog button.
The conversion of the FSB pod into something more useful would be cool. I would like to see a linear LED bar indicator for manifold vacuum but haven't found a sender unit for the 0-5V signal.  Any ideas????
John
This is available from a FAQ member that made a great 3 gage digital gauge in the pod, I don't remember his contact info
