Looking for a clear picture
SplitDash
That flat spot ties into the A pillar and the floor pan, right near the main beam that comes down from the front suspension. It is also doubled up thickness steel.
The tab that was used by the factory for pulling down the production line gives that flat spot a lot of stiffness. It would be weaker without the tab. Further, the tab helps locate a jack or a lift point (if I ever buy a two post lift).
I’m glad I fabricated a replacement tab for that area. Of course, this area was very rusted out before I started the restoration...
Alternatively, you can jack on the main beam that goes under the floor pan, but mine had been banged up severely and had rust. I wound up replacing the bottom of one of those beams.
Edited by slowbert
