Distributor compatibility
Daily02
Go to solution Solved by tech71,
But to @Daily02’s point, I believe that 1974, 1975, and the California version of the 1976 were capable of vacuum retard. And I haven’t a clue about e21 distributor advance! 🙄
I’m betting Tom and Tom Two — distributor enthusiasts that they are — will jump in at any minute.
Best regards,
3 hours ago, Daily02 said:
I have a 1974 2002, and I would like run an earlier distributor with vacuum advance
You can just change the vacuum capsule and retain your distributor.
If you truely want to be "Master of The Timing Curve Domain" why not buy a 123 distributor? Just be sure to get the one that doesn't spew oil on to the circuit board.
Edited by tech71
76 2002 Survivor
71 2002 Franzi
85 318i  Doris
The '74s had vacuum retard.
All '75 & '76 California cars had both vacuum retard and vacuum advance.
'76 49-state cars had vacuum advance.
Sorry @Daily02, I don't have any info on the '69 or '70 dizzy.
If you want a distributor with NO vacuum (advance or retard), then look for a Tii dizzy.
Whatever path you take, make sure the vacuum line is connected correctly. Do you still have/use the black electro-valve, coolant switch, and EGR relay?
John
PS: Steve @Conserv...I'm having fun with my new skill.
  • Haha 1
