Running bad lost power
njmolinelli
I was driving my 75, and all
of a sudden it started sputtering and running really rough, lost all power, got back to my shop and pulled spark plugs, back 2 were wet had fuel all over them, had really low compression, what would cause this? Blown head? Has this happened to any one? I haven’t torn into the motor yet.
Quote
Fix your fuel delivery problem.  I'll bet your missing compression comes  back
when the cylinders aren't washed down with gas.
Float sinking, float valve leaking, fuel pressure too high...
things like that.
  • Like 3
things like that.
Optimist!
:D
  • Haha 1
Ray
Tell us more about your '75.
Carburation (stock Solex or Weber (model), cleaned jets, float needle and power valve, float (plastic or brass).
Ignition (distributor, plug wires, points, condenser, or electronic).
Fuel system (mech. or electric pump, pressure, filters, fuel return).
Vacuum devices (brake, advance/retard, fuel return valve, dashpot, EGR, air pump).
If this happened suddenly as you described, it's most likely something fairly simple e.g., debris in fuel (keeping power valve open), stuck float or a torn accelerator pump diaphragm.
John
Agree it could be fuel delivery related. I had a similar issue recently. Turned out the secondary Venturi on the primary barrel of my 32/36 Weber moved and twisted out of position. It was loose in the holder so must have just rattled around.  Replaced and rebuilt the carb and has never run better!  Easy to check by just removing your air filter.
John
A compromised head gasket - especially between cylinders might easily account for the symptoms you describe but there are many other possibilities.  That said, a thorough description of the engine condition might prove helpful to any long-distance diagnosis.
The above suggestions would ordinarily be encompassed in a standard tune up.  Checking valve lash is always prudent as is a simple compression check.  I recall someone with similar complaint.  The engine was so poorly maintained that the owner failed to notice several severely worn camshaft lobes that clearly affected engine operation.  This does mean your engine suffers from the same malady, but it is a possibility in a poorly maintained high mileage engine.  Lastly, if cylinders 3 and 4 had wet spark plugs, what was the condition of the plugs from cylinders 1 and 2?  If your engine is fitted with a single carburetor, one might expect that a fuel delivery concern would affect all four cylinders assuming that the same carburetor supplies all of them with air/fuel.
Edited by percy
Yea 3 and 4 were covered in gas, carb is tight, looks clean nothing is loose, has 32/36 web, all stock, all had low compression, plugs 1-2 were dry, all were replaced a few months ago,
it does have high mileage, but before this it ran good, good compression,
msd ignition
Thank you for the additional information.  I thought your initial post implied that the compression drop was only on cylinders 3 and 4.  Did you do the compression test on a warm engine?  You'll get lower pressure on a cold one.  What were the readings?
Are you still getting spark on all four cylinders?  I don't know much about MSD systems, but maybe it crapped out on #3 and 4.  Did you inspect your cap for cracks?
I've had plug wires fail, but having two fail at once seems unlikely.
EDIT- A broken engine mount can let the engine rise up and break the distributor cap.
Edited by '76mintgrün'02
3 hours ago, Son of Marty said:
Before you go any further do a compression test, it will confirm or eliminate the head gasket.
Oh I dunno...
... I'm pretty sure the head gasket is there.
:D
You're welcome!
Ray
