MVP aftermarket turn signal problem
slowbert
In boating an Outboard refers to an engine bolted to the transom.  An Inboard is a boat with the engine mounted in the hull and the prop on a shaft extending thru the hull.  And then there is the Inboard Outboard stern drive with the prop on a drive mounted on the transom, then the jet boat .........  If you are Overboard, then you are SOL.
Edited by jimk
  • Haha 2
