BMW Engine Turning Tool 7008-1 Now Available!
halboyles
Price: $139
Description:
It's finally available!! We’ve resurrected the marvelous BMW Engine Turning Tool #7008-1. We used 4140 steel and had it hardened to RC 48/52 tool grade steel. We then had it black oxide treated to produce a long lasting, corrosion-resistant finish. This is one of those tools that will be passed down for generations.  Whether you are a DIYer or vintage BMW shop, this will be one of your most treasured tools.
Need to adjust your valves? Set the dwell angle on your points? Find TDC to stab a distributor?
You could use the old methods of turning the engine:
  • Put the car in fourth and push it (unless it’s on a slope)
  • Bump the motor with the starter (never stops where you want it to!)
  • Push on the fan blade (bad for the fan and your knuckles!)
  • Try to get a socket on the crankshaft nut (requires two people)
Or, you could simply turn the engine with THE AMAZING BMW ENGINE TURNING TOOL!
The Engine Turning Tool works with any dual-row timing chain for BMWs from the 60s to the 90s.
Order yours today on our updated e-commerce website: https://www.2002sonly.com/product-page/timing-chain-rotation-tool
Edited by halboyles
words2
  • Like 3
BMWCCA  Member #14493
www.2002sonly.com
