Dyno'd My Car
  • 2 months later...
On 5/22/2023 at 7:13 PM, 72MetallicMalaga said:
@jp5Touring see attached images for air corrector, emulsion tube, and main jet numbers (200, F11, 115)
I also added an image of the idle speed screw numbers as well (45, F9)
@jp5Touring did you ever get your lean issue sorted?
I finally have time to tinker with the carbs this month, might try just upping my mains to 120 or 125 to compensate for the 200 air corrector jets. As @Furry Camel states, motors starved for fuel in the upper rpm range on my motor.
'72 Metallic Malaga 2002 with a '73 M10 | Dual Weber DCOE 40s | E21 5spd and LSD | Pertronix II
@72MetallicMalaga I still have to adjust it a bit more.  I changed acc to 155 and still lean under full throttle. I'm running 130 mains, f16  e tubes and at 50f9 idle jets.  Runs pretty good at 3/4 throttle but will lean out at full throttle.
I'm not overly confident in my distributer so I purchased a 123 that I need to install still.
Just been crazy busy this Summer, hopefully next couple of weeks I can dig into it again.
thx
If memory serves me the f9 e-tubes are a bit richer at the top end than the f11's. The m10 does like to run on the lean side at top rpm's, but nothing too crazy on the lean side. this is for n/a engines, you booster just keep doing the Voodoo you do.
George S Patton
