Rear Parcel Shelf
Scott W. Long
17 hours ago, 02Les said:
Clamp for shelf lining 51 46 1 807 883  (3 req'd)
The three parcel shelf holes are indicated on @NYNick photo (had to point them out amongst the other holes 😬).
My pic is the center clip from the trunk side. Just pinch and push upwards to release the shelf.
19 hours ago, John76 said:
Just push these upwards from inside the trunk.
No need to remove the rear seat back.
Easy peasy!
True, but you need to carefully compress the little plastic legs to clear the hole in the metal or they'll break.
John in VA
Correct, crawl through the Jefferies Tube and use a tricorder to first determine the molecular degradation due to thermal expansion and contraction cycles. If need be apply some Dilithium lube.
  • Like 3
  • Haha 1
But what do I know
57 minutes ago, conkitchen said:
I'm beginning to think this forum might be one of the only places where people will debate the tiniest of insignificant things.
Why not?😃.   At least we aren’t debating stickers again…
  • Haha 2
id batten down whatever you use as shelf. things “stay” fine until they're launched in an accident. plastic clips probably ok for the nearly massless oem shelf. if you beef up the shelf, to a thick plywood for example, id screw it down into the two threaded mounts welded to the shelf sheet metal near the c pillars.
Edited by Howardpowered
typo
On 1/29/2023 at 5:49 AM, NYNick said:
What? I'm almost done! LOL
To change the subject...Is this car still for sale? I'm not buying, just asking for a friend. 🤥
(1973 Fjord Blue 037) Vin 2588314- Build date February 6th, 1973- delivered to Hoffman Motors NYC February 8th.
